Originally Posted by redeye280z
I got these 2 codes after I change my AOS and cleaned out the air intake. I know these codes mean I probably have a vacuum leak. I can actually hear some hissing so I started checking all the hose and I found that this line leaks when I move it a little. Can anyone tell me what this is exactly and how hard is it to replace. It's the hose circled in red.
That hose supplys vacuum to the power brake booster. The connecter at the intake manifold has a nylon "C" shaped shim to lock it in place, make sure it is doing it's job. There is also a small O-ring seal at the connection secured to the intake by 2 screws.
Your codes indicate your SAI is not effective, so if you hear the pump operating after a cold start it is not effectively leaning the AFR seen by the secondary O2 sensors.
Check the link posted by Timco.
