The plastic gear inside the transmission might be broken.
I had the same problem, first tried to change the motor, didn't help. Then I found out about the plastic gear issue, swapped it with a metallic one and now everything is fine.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
