Rick, don't listen to Burg, don't even waste the time, you need a new cap, trust me. They aren't very expensive. It will take care of the problem, but don't forget to bleed the coolant system. If you type a search for bleeding the coolant system you will see exactly what to do, since my description is thin. It is about the easiest thing you will ever do on a boxster.
