*update*
Using a dental mirror I was unable to find any of the bits from 6's tube. The section of the coil boot that was stuck in the oil passage fell down into cam cover. And... When removed the spark plug I discovered the male end that the coil attaches to is missing. Probably in the cam cover as well.
Question:
If I remove the sump and pump oil into the cam covers will it flush everything out to the sump to be caught in a bucket? (Trying to avoid removing cam covers in the driveway)
Located in Central Mass.
'00 Boxster
