Old 06-19-2015, 07:38 PM   #2
ccjazz
ccjazz's Avatar
Here's the deal.
Although you won't have quite the access to the top of the motor with the 03 top/frame, its not an issue at all. Once you see how easy it is to install the whole assembly...three bolts and two screws on each side, you'll realize that if you really needed full access to the top of your motor, you can simple remove the entire assembly and get after your repair.
The glass window top is worth it!
Thanks dg, this sounds like the way for me to go.
'01 Boxster S (purchased new) triple black, litronics, cruise, heated seats,18's.
ccjazz is offline   Reply With Quote
