Originally Posted by camille
Hmm. Say, tommy583, might an aging center motor mount also explain thunking and shuddering when accelerating briskly from a stop sign in second gear (tiptronic's default)? There's no shudder when accelerating in 1st, or gently in 2nd. (This car has about 100k miles on it. I've had it for a year. Sixth owner.)
Yes that is another common symptom of a failing motor mount. When I say center I mean the front, not the side (transmission) mounts. Although they could be getting to the end of there life as well. I would definitely say your front mount needs changing. There are plenty of DIY guides on how to do it. If you took it to a shop I would figure on a couple hours labor at most.
