Old 06-19-2015, 06:00 AM   #10
Bayley
Registered Abuser
You shall overcome!
'Tis but a minor setup in your final steps to the summit.
BTW - let me know if there were any modifications you did with the belts or brackets. My AC bracket had some pretty bad interference with the compressor housing. I wrote Renegade last week just to give them a friendly "heads up", still haven't heard back. In the meantime, I modified the bracket to both clear the compressor housing AND fit the engine block a little better. Renegade's powder coater was a little overly ambitious and a lot of the holes and aligning edges didn't fit until I ground off all that beautiful finishing coat.
At the very back of the compressor housing near the rear mounting bolt, you can see the housing hitting the bracket:
Wasn't difficult to modify, but yet another aspect of this "kit" that makes it less and less of a "bolt in" experience.
Bayley is offline   Reply With Quote
