Old 06-17-2015, 11:41 PM   #1
barks
i cant believe that if the timing was out on bank 2 it wouldnt tell me?
but if thats true then the same issue could be with bank 2 and both caused by o2 sensors.
unplugged maf seams a bit better,
i looked to see if i could swap the front and rear o2 sensors and they look the same.
looking under the car i only have 2 rear cats?
manifold-curved straight through pipe with an o2 sensor in it-rear cat with o2 after it-silencer
ive read that faults codes can differ with dme revision so checking that to make sure.
if the mechanic that did the compresion test didnt dissable the ignition system would it be possible that an arcking coil pack could have trashed the dme ?
regards
barks
barks is offline   Reply With Quote
