I did use a protectant from a different brand. I don't recall if it was duplicolor. I had the same concern. The Mothers kit has everything that you need to eliminate deeper imperections, but then leaves the plastic exposed to UV.
If the sealant that I used was something different, I'll grab some of the duplicolor. while the process was veyr smooth, I'm not eager to do it again any time soon.
