Old 06-15-2015, 06:35 PM   #10
stilov
What can you tell me about the 74mm TB?
Seems that I have found my answer. The 74mm TB which is a 997 part number does not work on the 996 turbo oem plenum.
Sort of sad since the cost of the 986 part number is almost triple that of the 997.
As JFP said... Even in the highly modded 996t world I haven't seen convincing enough data to drop that much money into buying the nearly 1000 plenum to make it work on my car.
I make 700 to wheels with the small 68mm TB. I just figured if it was cheaper to get the 74mm is give it a shot since I have to replace the TB anyway.
Last question, in the 986 community, do you guys find TB failure common?
stilov is offline   Reply With Quote
