Thread: Engine coolant
Old 06-13-2015, 08:55 PM   #10
newBgeek
Originally Posted by Orangebob View Post
not sure if I should replace spring clamps with jubilee ones at same time
Pat Goss from Motorweek made a very good point about the jubilee, worm-drive, or screw-type clamp. He said the spring clamps apply even pressure around the hose, while the screw clamps have a pressure point under the screw which can crack plastic connectors over time. Makes a lot of sense. When you think about it, these things are heating and cooling all of the time. You really want a clamp that can expand or contract with the heat expansion or contraction of the hose and plastic connector. Personally, I'm sticking with the spring clamps that came with the car.
newBgeek is offline   Reply With Quote
