Originally Posted by eslai
Did you check out the 987 amberectomy thread I linked to in my signature?
987 Amberectomy
I just went to the link to Dons Bulbs in that thread and curiously enough, the 7506 seems to be just about identical to the 7507--the difference being the bayonet connector is different--one of the nubs (for lack of a better term) is offset by thirty degrees on the 7507. I guess that allows the bulb to always be clocked in a given direction. Neato.
So I guess 7506 is bad, 7507 is good. 7225 looks similar but I don't think it's correct as the owner's manual states that the bulb is a PY21W. The 7225 is listed as a P21-4W. What all that means, I have no idea...
the way i figured out the 7225 works is that the other rear bulbs (brakes, etc) are 7225 and i pulled one out and it fit perfectly in the front. actually, if you look on don's bulbs, the 7225 is synonymous with the py21w. sylvania guide incorrectly lists the front blinker as a 7506 - it also has incorrect info for the 987 high beam.
Mach Schnell
05 Mini Cooper S
CR/W - AC Schnitzerz'd, Alta CAI, Cravenspeed SSK
Japanese Rising Sun roof graphic
De-ambered and nearly de-chromed!
Sold - 05 BMW 330CI ZHP M-tuned
Imola Red, 6spd, Alcantra & Carbon Fiber Interior
Sold - 05 Boxster Black/Black 5spd
19" Carrera S Wheels
Bose Audio System/Sport Chrono Pkg
Schnell Short Shifter
Yellow Calipers c/ carbon fiber Porsche lettering
De-Ambered
Sold - 03 VW Beetle Silver - way too modified!
