Originally Posted by mach schnell
I have a set of 7506 silver style bulbs that blink super white. Turns out that the 987 model actually uses a 7225 for the front blinker. These(7506) fit the rear blinkers (at least on the 987 and prob on the 986) even though the designation is 7507 and may actually work for the front blinkers on the 986 if they use a 7506.
Did you check out the 987 amberectomy thread I linked to in my signature?
987 Amberectomy
I just went to the link to Dons Bulbs in that thread and curiously enough, the 7506 seems to be just about identical to the 7507--the difference being the bayonet connector is different--one of the nubs (for lack of a better term) is offset by thirty degrees on the 7507. I guess that allows the bulb to always be clocked in a given direction. Neato.
So I guess 7506 is bad, 7507 is good. 7225 looks similar but I don't think it's correct as the owner's manual states that the bulb is a PY21W. The 7225 is listed as a P21-4W. What all that means, I have no idea...
