Old 06-13-2015, 05:32 AM   #1
Hummer-addict
Hummer-addict's Avatar
When you do the IMS you might as well do the clutch,flywheel,clutch fork,slave cylinder and rear main seal...I also had the water pump, thermostat and belt replaced at the same time cause I was there...it's a pricey job but way less expensive then a new engine...sorry to hear and good luck
Hummer-addict is offline   Reply With Quote
