Old 06-12-2015, 08:56 AM   #2
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by Deserion View Post
Basically, the cables inside the regulator are losing tension and the window won't drop due to that. Search the forum, there is a fix by way of using a barrel adjuster from a bicycle to repair the issue. Or, replace the regulator.
thanks i found good info that should help.
i found your thread as well and it seems you had the same issue. did you end up replacing the regulator again or do the barrel adjuster fix?
CrisZenithBlue is offline   Reply With Quote
