cover the 18 pin on the top relay(big white block next to the fuse panel) and the top will go down at speed. You only need to have one click of the ebrake so that the light comes on the cluster.
I used it for quick up and downs of the top when at a light. But doing it at speeds of more than 10 mph is not wise. You can put some wind into the clam shell and screw up the alignment.
BORN: March 2000 - FINLAND
