Old 06-06-2015, 06:12 PM   #7
ilikeching
Usercpy
ilikeching's Avatar
Originally Posted by mgfranz View Post
Ok, so I got a chance to dig into the door panel today to do a bit of troubleshooting, the switch is fine, turns out I have faulty wire or connector in the door harness that is either open or shorting out near the door latch. Wiggling the harness near where the connector for the switch and the main door harness come together caused all kind of havoc with the window and the door light. I'm thinking I have an open wire somewhere or a bad connector.
I had the same sympton, i found lots of cracked wires(near window goes up/down grinding the wires) rubbing each other and causes lot of weird sympton.
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
