Old 06-04-2015, 07:30 PM   #1
EJ-Fresno
EJ-Fresno's Avatar
Originally Posted by smcintyre6492 View Post
To illustrate what I was saying above, here are a couple of pictures:
"Old Normal" operating temp
"New Normal" operating temp
and it will get a little higher than that.
One other data point. This morning, I got stuck idling/crawling in traffic behind an accident. Outside temp was about 75F. While I was sitting, the temp spiked up beyond that second hash mark; the needle was going through the 2 on 250. It took about ten minutes before this occurred, but it when it did happen, it wasn't gradual, it happened over a couple of minutes in a couple of leaps. I've never seen it that high. The moment I started moving again, even slowly, the needle came back down to the new normal.
Should I be concerned?
Totally out of the subject, and I apologize in advance... But how can you get 3 lines in the OBC display? I can get only 2... Maybe because I have a 2003?
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
