Thread: V8 Conversion
Old 06-02-2015, 07:45 PM   #10
martsink
Today I tested an early 986 Boxster throttle cable to see how it would work with the engine. From what I’ve read on other blogs, the cable is too short and the pedal travel only gives you about 60% throttle. The only alternative is to run a drive by wire setup, which requires some fabrication to mount the GM pedal and a lot of money to buy the whole setup. I would have to get a C5 corvette ECU, harness, TAC module, and pedal. This setup is about $800 used if you can actually find it. I was able to find a cable and pedal setup from an early 986 Boxster for $50, so I decided to give it a try first (these are rare, but believe some pre 99 models came with cable throttle).
There are no mounts on the new chassis for the cable, but it’s easy enough to bolt on. The cable is perfect length and you get about 90% throttle without any modifications. If you grind down the pedal stop you can go up to about 95%, which I am happy with. I will have to figure out a custom throttle cable bracket, but that’s pretty much it. The other issue is the space for intake hoses, but that's a whole other project.
martsink is offline   Reply With Quote
