			Do you have a Durametric? Is that the only code you see? How are your cam deviations? How about RKAT readings?I would also suggest rechecking your wire connections into the packs. These need a little finesse to assure that they are properly seated (making a good connection). I had this problem recently and the cause was just that!
www.youtube.com/channel/UCohdrH2xHTklM1thxk0KKOQ? |
