The brackets attach to the roll bar with pop-rivets. The brackets come with new rivets. You'll have to pull the roll bar pads off , as the part of the bracket with the rivet is under the pad. I'm not sure if the bar will be pre-drilled from the factory, or if you'll need to drill them yourself as Randall pointed out.
The padding is held on with some of those ribbed plastic things, so you can remove them pretty easily. Take a look and let us know!
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
