Old 05-31-2015, 03:11 AM   #457
itsnotanova
Originally Posted by bobbeck View Post
Looking for a set of clear headlight corners. Thanks!
Sorry I don't have any. It's best to buy those new. Most of them are brittle when they come in and the tabs usually break when you try removing it from the headlight.
Originally Posted by Wild Bill View Post
I imagine the condition is good? If so I will buy them from you, are they hard to change out?
I'm 90% you can switch from your 97 to the 03 cables/trans brackets with no problem, but you need to double check that. Getting access to the shifter will be the hardest part. You'll need to remove the center console. Good time to upgrade to a short shifter too.
Woody
