Thread: Stiff Clutch
Old 05-30-2015, 05:26 PM   #4
Wife's Boxster S
squeak behind driver seat
The rattle could possibly be the wind deflectors behind the seats if the seats are pushed too far back.
The airbag light is a really common issue that has to do with the seatbelt latches, however usually if the code is cleared the light stays away at least for a while. Since yours does not, maybe you should actually be concerned.
It was the driver's seat belt latch. Replaced it and no more warning.... After more searching on the "squeak rattle" behind the driver seat going over bumps I believe it might be the bushing on the control arm. It is certainly in the right spot. Gonna change both out and see.
Wife's Boxster S is offline   Reply With Quote
