Old 05-30-2015, 01:50 PM   #101
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by Ben006 View Post
I didn't read everything because I'm on my phone, but pulling air and pushing air is the same.
The engine does not pull air into it, the air is pushed inside because the atmospherique pressure is greater than the pressure inside the combustion chamber.
Yes, that's the principle of why air wants to "move into the engine", but the engine is working like a pump too. The downward stroke of the piston with the intake valve open creates a pull on the air into the cylinder. The rings on the piston are just as important to filling the cylinder with air as it is to the compression of the air.
2003 Boxster S
