Old 05-26-2015, 03:26 PM   #12
JFP in PA
Originally Posted by Steve Tinker View Post
If you have excess pressure in the cooling system then the pressure must be coming from somewhere.
1)It can't be the pump as I doubt it could compress up to ~ 20psi even with near boiling point water.
2) It could be a blocked engine / radiator vent line (#11 & 12 in diagram) but ??
I'd hate to think that you have a cylinder head crack opening up when hot and combustion gasses are "pumping up" the cooling system....
This is exactly what I posted to the OP on another site (http://www.renntech.org/forums/topic/48478-too-much-pressure-in-coolant-tank/), and suggested running both a leak down on the engine and checking the vapor above the coolant in the tank for combustion gases using one of these:
That excess pressure is coming from somewhere other than the cooling system.....
