If you have excess pressure in the cooling system then the pressure must be coming from somewhere.
1)It can't be the pump as I doubt it could compress up to ~ 20psi even with near boiling point water.
2) It could be a blocked engine / radiator vent line (#11 & 12 in diagram) but ??
I'd hate to think that you have a cylinder head crack opening up when hot and combustion gasses are "pumping up" the cooling system....
2001 MV Agusta F4.
