Old 05-26-2015, 06:51 AM   #3
Qmulus
inveniam viam aut faciam
Originally Posted by whitecliffs View Post
Was looking to change over to a 996 instrument cluster I'm in the UK and there's not many available so found one that will fit/work for sale in the U.S. Only difference seems to be the temperature gauge.
Then I see this on pelican tech page
"If you are located in the United States, be sure that you get a cluster that is a US-spec unit, and has the main speedometer gauge delimited in mph"
So are your speedos limited in the U.S. Then and won't read over a set speed.
No, they mean that speedometer reads mph, instead of kph as in other countries. I think using "delimited" is not the best choice of words. A US cluster would work fine for you, as long as you don't mind the temperature gauge being marketed in Fahrenheit rather than Celsius.
Qmulus is offline   Reply With Quote
