996 instrument cluster
Was looking to change over to a 996 instrument cluster I'm in the UK and there's not many available so found one that will fit/work for sale in the U.S. Only difference seems to be the temperature gauge.
Then I see this on pelican tech page
"If you are located in the United States, be sure that you get a cluster that is a US-spec unit, and has the main speedometer gauge delimited in mph"
So are your speedos limited in the U.S. Then and won't read over a set speed.
