Old 05-25-2015, 04:47 PM   #19
Jamesp
Beginner
Jamesp's Avatar
I had three engine failures last year. This is what one of the filters looked like.
Even if the oil is flushed a couple of times and the IMS bearing is replaced, other components are already damaged (even if the engine runs) from all of this debris. If you can live with this, go for it; but it would be irresponsible to sell the car to an unsuspecting buyer.
I think other parts *may* be damaged. I followed the trail of the metal chips in my engine when I tore it down. The timing chains carried the chips into the heads and back down into the sump area. The oil carried it to the oil pickup, then through the oil pump add into the filter. Upstream of the filter there was no evidence of chips, the oil galleys were chip free, and the cams and springs were chip free. The Variocams were chip free. The timing chains had a few chips. The chain ramps had lots of chips imbedded in them. The sump area walls were coated with chips. I agree reselling this car would require full disclosure of the failure if that is what happened.
2003 S manual
