Old 05-25-2015, 02:14 PM   #1
Steve Tinker
Steve Tinker's Avatar
Is the pressure relief valve leaking (located under the plastic cover below the coolant / oil fill caps)?
If you remove the plastic cover and see residue, its a good sign that the O rings are leaking when hot. You can try lifting the chromed D ring to its vertical position for a few days heat /cool cycles to make sure its not leaking condensation from the valve area.
2001 MV Agusta F4.
