Old 05-25-2015, 02:50 PM   #16
thom4782
thom4782's Avatar
Hi everyone:
I've occasionally seen a P0430 code on my 01S over the last 12 months. I've been trying to make sure its the cats causing the code before I spend the big bucks to replace them.
My understanding is that the after-cat O2 sensor voltages will look flat if the cats are working properly. If the cats are weak or bad, then the after-cat O2 sensor voltages will fluctuate like the pre-cat sensors.
Is this true? Is it is, are there any other conditions other than a weak or failed cat which would cause the rear O2 sensor voltages to fluctuate. Or does fluctuating rear O2 sensor voltages pretty much confirm the problem.
