Thread: code P0343
Old 05-24-2015, 02:57 PM   #3
kiyakubuke
one down, one to go
went in to check the wiring and connector to the Camshaft Position sensor. unplugged the harness and checked it, looked ok, reconnected it. traced the wire up behind the J tube where it connects to the AOS. removed the J tube for a better look and immediately saw that the connector was completely pulled out. it was still clean and shiny, so it is pretty clear that I somehow managed to pull this loose while I was replacing the AOS.
In any case, plugged it back in and reset the fault codes. hasn't come back yet so I hopeful that this solved the p0343 code.
Now I just have to solve the P1126.
kiyakubuke is offline   Reply With Quote
