Going to pull the pump and bench test it. Nothing better to do. Called around, none on the shelf anyway unless Porsche has one tomorrow.
So, with a Durametric, I can turn each of these items on and off and check them that way with key on? Is that a feature of this tester?
Ummm, no. Have to siphon gas out, get a glove, and I'll want to swap hose by hose with the new one. I'll order both. Thanks KRAM. I'll check locally tomorrow then order what I can't get. If a pump is local I'll do that since its easy to get to the sending unit.
'08 VW Touareg T-3 wife's car
Reason: Abort!!
