Originally Posted by Steve Tinker
As you have probably guessed, the fuel pump will not start until the engine is running, apart from the initial few seconds run when the ignition is first switched on.
To get the pump to run, are you removing the relay and jumpering pins #30 & #87 (they are labelled #3 & #5 on the relay).
When you switch on the ignition, the pump should run - if not you have a pump problem....
Pulled the harness. 13v for a second then 9.8v while cranking. I'll pull that relay and check voltage with the jumper in place. Then if it has juice, it's the pump.
With that jumped out, I only ever see 3-4v. Never says 12-13.
Then with relay back in its as described above.
'08 VW Touareg T-3 wife's car
