Thread: code P0343
Old 05-22-2015, 04:16 PM   #1
kiyakubuke
code P0343
anyone know if pulling the camshaft position sensor (hall sensor) wire loose (or partially loose) would cause a code p0343?
I just replaced my AOS and Oil filler pipe, after I started the car back up I almost immediately got the code.
since that sensor wire runs up close to the AOS, it is possible I hit it while installing the AOS. Looking at it earlier, I see a wire running from the sensor to a connector, then up under the intake. everything seemed ok, but could not see well enough under the intake to know if it was fully connected.
kiyakubuke is offline   Reply With Quote
