Old 05-22-2015, 08:55 AM   #2
Xcellr8
Close thread - problem was bad pressure plate
Hi all that helped on this. Problem has finally be fixed when the pressure plate was replaced.
To summarize - discovered the problem was that the clutch would not disengage.
Confirmed that the clutch release lever was moving when clutch pedal pushed. Already had installed new release bearing, so, we knew that the pressure plate was not doing its job. Sure enough, replacing it fixed problem.
Either I can't recognize how much wear to the fingers is too much wear thus the pressure from the release bearing was not sufficient to spring the splines, or there was another problem, i.e weak splines that when pressed didn't release the pressure plate from the clutch disc.
Thanks for everyone's input. I know many suggested doing a complete clutch job from the beginning, and that would have worked, but then I wouldn't have learned all that I did chasing dead-ends. It was an education that I'm sure will help at some point in the future.
Thanks again,
Joe
Xcellr8 is offline   Reply With Quote
