Old 05-20-2015, 08:15 AM   #11
Heiko
Heiko's Avatar
If you have a Ohm meter, pull the connector and put probes into pin 1 and 2 you should read around 800-1000 ohms, then repeat the same test for pin1 and 3 and it should show infinite (meaning open/as if not touching). If either of these is not the case I would replace the CPS.
Hope that helps
H
Previously owned:
