I didn't read some pages of the post, but what parts of the clutch assembly did you replace? Had same symptoms recently with hard to engage gears. Slowly turned to impossible to engage any gear unless motor was off. My pressure plate was broken (creaky) and the clutch fork was cracked (I assume less cracked/bent when selecting gears was still hard but possible, i.e. the stage you are at). Hopefully those were part of the replaced parts list?
