Hi,
The Boxster uses Directional Tires. Directional Tires are designed to improve wet-road traction and have an asymmetrically designed tread to provide more rubber contact on the outer edge of the Tire with the road.
Directional, high performance tires are mounted with the arrow on the top of the sidewall pointing in the direction of travel. When these tires are rotated, it is important that they remain on the proper side of the vehicle. Since the Boxster uses a different size Tire Front/Rear, they cannot be rotated. Hope this helps...
Happy Motoring!... Jim'99
