Old 05-15-2015, 06:58 PM   #4
JFP in PA
OK, most likely candidate is a wiring short to ground on the AC compressor clutch circuit. Check the control wire of the AC relay (pin 2 or terminal 85) for a short circuit to ground. If it is shorted, you are going to need to trace the harness looking for the short.
