Old 05-15-2015, 03:11 PM   #1
Drahthaar
Drahthaar's Avatar
Steering wheel not aligned after trans fluid change
I did a transmission fluid change on 03 S 6 speed and now the steering wheel is a little to the left when traveling straight. Doesn't seem to pull one way or the other. I'm guessing it's related to rear suspension alignment due to removal and reinstallation of aluminum braces and protective plate to access trans drain plug. Any easy fix? Should I just leave it if it's not pulling and seems to be handling fine?
Thanks!
03 Boxster S
Seal Grey/BLK/BLK
6 spd, LN IMS Retrofit, 997 style RMS
Drahthaar is offline   Reply With Quote
