Old 05-13-2015, 09:21 PM   #1
BoxsterPHD
BoxsterPHD's Avatar
Push in the plastic pins in the centre of the the three plastic rivets. They will fall inside the spoiler but you can retrieve them later. Pull out the rivets and the spoiler top clips off. I think there are plastic end caps on either end of the spoiler too that pull out. The metal part is held on with two Allen bolts which you can see once the plastic top is removed. Been a while since I took mine off.
BoxsterPHD is offline   Reply With Quote
