Old 05-13-2015, 06:32 PM   #3
Heiko
Heiko's Avatar
Originally Posted by Steve Tinker View Post
Thanks or the heads up Heiko... I'm assuming to are referring to BoxsterSteve re loaning the cam lock tools - I'm a long, long way from ON!
A couple of quick questions for you or the gurus:
1) Any pics of which one is the IMS tensioner?
2) If I wanted to replace all 3 chain tensioners, can I still just lock the crank pulley @ TDC?
3) Do you need to drain the oil before starting?
Thanks everyone
Well you can borrow them too if you want but yes it might be a wee bit of a ride (you may need floats on the Boxster to get here lol)
If you lock TDC with the pin just make sure you do one at a time and you should be fine... I've done a few and never had an issue as long as you don't turn the engine.
I've always done them in conjunction with and oil change but I'm pretty sure you'll dump some oil doing Bank 1 (passenger side) and the IMS tensioner (lower center) if you don't drain it. Here is the markings on the tensioners to show you where they go.
Previously owned:
