Old 05-13-2015, 07:28 PM   #12
Pdwight
Pdwight's Avatar
Like I said I have done my seats and carpet. Clean and prep, clean and prep. You will be spraying this on so a calm air environment is a must. Be prepared to put 5 to 12 coats to completely dye it and each coat will need at least 6 hours to dry. On problem areas where it might be a bit thick as far as the dye goes use a heat gun sparingly to set the color and let cool before respraying. I used two cans of propellent and could not find it locally so order at least two cans. You will not be able to use the last 15% of the propellant can because it will not have enough pressure to spray the dye. A cheap 12 dollar HVLP gun would be better and then just dispose of it after you are finished.
