Old 05-13-2015, 09:53 AM   #11
Pdwight
Pdwight's Avatar
Perhaps not a fail
I had the same situation when I did my install, I drove to another members home and he had a PIWIS (spelling?)and it still did no good. What it turned out to be was a connection. Double check the connector you inserted the pins into at the back of the instrument panel, make double sure it is completely plugged in all the way...easy to have it askew .
Also be sure none of your pins pushed out of the connector....if you saw the triangles they should stay in place.
Next thing to try is the actual 4 stalk, I had a cold solder joint in the OBC lever on the ground.....easy to "Ohm" this lever out.
Let me know if I can ever help
Dwight
