Old 05-12-2015, 10:52 AM   #7
Perfectlap
Perfectlap's Avatar
Originally Posted by chromecarz00 View Post
Only thing I can think of is that I got a faulty microswitch, but that just doesn't seem likely - the old one really didn't seem to have any issues when I took it out. There was another module in the overhead light area though, but I think that was the alarm?
The switch in the winshield that you see in the overhead light probably has loose or corroded contacts -- need electrical contact cleaner. Check for instructions on Pelican to remove.
EDIT:
Instructions from forum member TheStone
"To get to the top microswitch, remove the two alarm covers (black plastic ovals) from the center windshield cover - they wll just kind of pop out with your fingernail or a very small screwdriver. Then use a Torx bit to take out the two screws. This will allow the center cover to drop down.
There will be three wire bundles - one for the courtesey light, one for the alarm module, and one for the top microswitch. Remove each of them by pressing the clips and pulling. The microswitch is a black module with two silver bars across it and the pressure switch for the latch is underneath.
Just use a pair of needle nose pliers to pull the retaining clips off while rotating them back and forth; be careful and they can be reused for the new microswitch. "
BORN: March 2000 - FINLAND
