Old 05-11-2015, 11:49 AM   #28
flaps10
flaps10's Avatar
Heliguy,
Yes. Single and Multi Commercial, non current CFII. My day job is flight deck design and I currently fly for pleasure.
Bootleg,
If I had an actual lift (which lifts the entire car vertically) then I would do it that way for sure. As it is, if you drop the engine/transmission together, the width of the engine would be too wide to make it past the rear suspension castings. You would either have to lift the car way up to clear it, or split the engine and transmission/pull the transmission out/rotate the engine/pull the engine out.
flaps10 is offline   Reply With Quote
