Old 05-08-2015, 08:42 AM   #10
BYprodriver
BYprodriver's Avatar
Originally Posted by Shape View Post
Thank you Timco and Jake.
Jake,
If the spark plugs are new only 100km, I will not be able to see a clean plug.
1) Should I run a leak down test or it will not show anything for a cracked head?
2) Should I have only one head cracked or both heads can be cracked?
3) I heard to diagnostic a cracked head is with blue penetrant liquid with compressed air, one people told me about laser, I never heard of that...
Thanks for all your help guys
Shape, the 2000-2001 heads are a thin casting & crack easily. Cracks may not leak until heated to operating temperature. Both can be cracked so you should remove engine then remove heads, have any cracks repaired,& insure there are no foreign particles blocking coolant passages in the heads. My 2000 did this @ 85,000 miles after water pump failure.
