Old 05-07-2015, 05:46 PM   #10
The Radium King
The Radium King's Avatar
Originally Posted by KRAM36 View Post
Just talked with the man at Softronic. He said using the larger 987 MAF Housing will yield no gain with the 996 TB, is could also hurt the cars performance even with a tune. He also said do not go to a larger TB, like a 82mm TB on a stock 3.2L engine (no internal engine changes). It will actually hurt the cars low end performance. The 996 TB he says is what to go with and stick to the 986 MAF housing.
umm ... so what was porsche thinking when they put it on the 550 and added 8 hp? the 550 is basically your engine with the 987 airbox / maf housing and a factory tune.
no gain? not likely. most likely no gain for softronic. you've been upsold. instead of 1/2 hour at your indy getting the spyder tune pushed onto your car, now you're out $800 to ... softronic.
