Old 05-07-2015, 01:40 PM   #1
Cebu
Headrest wind screen..
So I picked up a pair of screens for my headrest. I seriously doubt the tabs will hold once the wind catches. I've read fellas are using either double sided tape, tie wraps or both to secure it down.
In regards to the tie-wraps I can see doing the lower sides around the bar but at the top portion where are you using the tie wrap? The way I see it can be done is if you wrap around the roll bar which cosmetically doesn't look so good.
I may end up using double sided tape on all areas and one tie wrap at the bottom in case it breaks free.
Any other ideas???
Thanks fellas!
Cebu is offline   Reply With Quote
